Logging on Digital In
Postby stevieturbo on Wed Mar 14, 2012 7:30 am
I want to log the output of an electronic boost controller via the Motec.
Is it as simple as hooking up the ground trigger to the solenoid to a digital input on the M800 ? Obviously it is a ground trigger only.
Not using the Motec for boost control obviously, but want to monitor the solenoids duty's for diagnostic/reference purposes
stevieturbo
Re: Logging on Digital In
Postby Scott@FP on Fri Mar 16, 2012 5:45 am
Pulse measurement then write a math that has the frequency of the boost controller's output, then you can determine DC%.
Scott@FP
Postby stevieturbo on Fri Mar 16, 2012 6:19 am
Not honestly sure if it uses a fixed frequency or not. It's mostly for reference anyway, so as long as the numbers are consistent, that's enough
it's a Turbosmart E-Boost 2
stevieturbo
Return to M800 Plug-In ECUs
