SUBARU N14 PROBLEM
SUBARU N14 PROBLEM
Postby dragcar2007 on Tue Mar 30, 2010 2:57 am
Did anyone ever had an issue on the latest subaru sti (2008) regarding clutch switch fuction?M800 pnp installed car started but every time clutch is pressed starter motor comes in even the engine is running.
Any suggestions???
dragcar2007
Re: SUBARU N14 PROBLEM
Postby Karel on Wed May 26, 2010 7:59 pm
I am running M800 on custommers N14, but no issue. It must be some wiring problem. Ecu does not send signal to the starter, just you with the keyswitch.... or not ?
Karel
Postby dragcar2007 on Mon Jul 05, 2010 6:26 am
That model is the one that subaru offers with some extras and it has no key switch but a controller and starter is engaged when pressing the clutch.Have you managed to run the m800 and having the abs working ok?
dragcar2007
Return to M800 Plug-In ECUs
