subaru version 7 coilpacks on a version 5
Postby scotty400 on Mon Dec 28, 2009 6:31 am
Hi all can you tell me if its possible to run version7 coil on plug type on my version 5 which has 1 big coilpack.And is it hard to wire this up.
scotty400
Re: subaru version 7 coilpacks on a version 5
Postby SprinterTRD on Wed Dec 30, 2009 8:18 pm
From memory You could use them but they will need to be wired as wasted spark. The 5 coilpack uses only 2 ignition outputs to fire the four cylinders but the 7 coilpacks need 4.
SprinterTRD
Return to M800 Plug-In ECUs
