M800 for evo vII
Re: M800 for evo vII
Postby RossB on Wed May 27, 2009 1:50 pm
We do not sell any products directly from here, can you contact a dealer in South America? Your Lambda sensor looks like a Bosch LSU 4.0. The good news is that this ECU is enabled with Lambda and data logging which will make tuning it a lot easier! You REALLY SHOULD NOT pull the ECU apart like you have!!! It is very easy to damage the connector between the ECU and the adaptor. There is no need to pull it apart like this!!!
RossB
Postby Kemoly on Wed Nov 04, 2009 7:00 am
The fuel im using is the same as the 93 oct USA fuel
Kemoly
Previous
Return to M800 Plug-In ECUs
Users browsing this forum: No registered users and 20 guests
