subaru 2008 crank ref setting ??
Postby jimarea51 on Sat Jun 06, 2009 7:51 am
Hi guys
can you tel me the correct (crip) crank index position setting for a 2008 subaru JDM spec 2 ltr double vvt engine ?
as the 3 base maps i have are all diferent from 547 to 580 !! and the release notes give 2 diferent setings surely on a production engine there cannot be that much error !!! i know its best to check this on each engine but i need to know that im in the right area to start with,,
the base map i was supplied had 580 and the engine sounds very retarded and got very hot on the exhaust at idle
thanks guys
jimarea51
Re: subaru 2008 crank ref setting ??
Postby jimarea51 on Mon Jun 08, 2009 8:15 pm
any ideas guys ?
thanks
jimarea51
Postby mhd on Tue Jun 09, 2009 10:02 pm
I think 560 coz I recive M800 OEM for 2006 STI in the base map was 580 after checking I found it 560 for the 2006 STI DBW, some people saied that it 550 also
the best way to check by your self
cheers
M.Olabi
ProRacing Co.
mhd
Postby RossB on Wed Jun 10, 2009 12:20 pm
According to my information it should be 447 on a dual vvt 2.0 enigine. I would always recommend checking it with a timing light though.
RossB
Postby jimarea51 on Thu Jun 11, 2009 9:05 am
thanks very much guys
jimarea51
Return to M800 Plug-In ECUs
