Build CAN INTERFACE CABLE
Postby Aljiru on Tue Apr 21, 2009 7:18 am
Hello¡¡¡
Could i build a CAN INTERFACE CABLE?
Parallel to NEUTRIK connector or Parallel to d9.
Thank
Aljiru
Re: Build CAN INTERFACE CABLE
Postby DarrenR on Tue Apr 21, 2009 1:09 pm
The Motec CAN cable has quite a bit of circuitry in the parallel connector shell so it is not possible to build one with out this interface circuit board.
Regards,
Darren Reynolds
DarrenR
Postby figgie on Fri May 15, 2009 2:37 am
aljiru
to add to Darren's post.
CAN is a serial interface with a serial transmission. What you are proposing is basically sending a serial stream into a parallel system that uses parallel data information. Not a simple task of doing that without adding a serial-parallel convertor in the middle and not any serial stream, CANbus.
Look at the older printers that had a serial AND parallel port on it. Not very easy way to go between both.
figgie
Return to M800 Plug-In ECUs
