SUBARU - EJ207 - ADD MORE THAN 11 SITES INTO LAMBDA TABLE
Postby jamel972 on Wed Apr 18, 2018 3:05 pm
Hello everybody,
I'm trying to know how can I add more than 11 sites into lambda table (Y axis, kPA). Into main fuel table I can set 20 sites (Y Axis).
ECU Manager
Production Version 3.52F2
Build 3.5.2.1
Firmware version : 3.52F
Many thanks for your answers.
Frederic
jamel972
Re: SUBARU - EJ207 - ADD MORE THAN 11 SITES INTO LAMBDA TABL
Postby David Ferguson on Thu Apr 19, 2018 3:06 am
You could reverse the axes so that you used the 20 sites (X-asis) for the pressure and the 11 (Y-asix) for the RPM (or other channel).
Postby jamel972 on Fri Apr 20, 2018 12:44 pm
David Ferguson wrote:You could reverse the axes so that you used the 20 sites (X-asis) for the pressure and the 11 (Y-asix) for the RPM (or other channel).
Hi David,
Thanks for your answer, I will space out the pressure because I need 20 sites RPM...
jamel972
Return to M800 Plug-In ECUs
