CEL Activation when ORB is active?
Postby Run/Stop/Restore on Mon Feb 22, 2016 6:18 am
i need some help with the CEL activation. A Customer wants to have the CEL blinking when ORB Table 1 is selected and a permanent CEL when Table2 is active. I already configured the ORB Select Switch but i cant remember how to map the CEL properly. The ECU manager doesnt allow me to use ORB Select as a Axis on the Engine Warning Table.
Thanks in advance
Run/Stop/Restore
Re: CEL Activation when ORB is active?
Postby Scott@FP on Wed Feb 24, 2016 9:46 am
You could use Status Flags 2/group 2 in a PWM aux table. Group 2 contains ORB Active and ORB table 2 in use flags.
Scott@FP
Postby Run/Stop/Restore on Thu Feb 25, 2016 7:41 pm
Thanks Andy, that nailed it. I thought "ORB state on" is a "warning" thats why i couldn't find the right function :oops:
Run/Stop/Restore
Return to M800 Plug-In ECUs
