SLM light not working
Postby qatarevox on Tue Aug 25, 2015 4:51 pm
Has anyone got the SLM light to work on the M800 for Evo X? I have tried a few different things but now I'm about to give up and just buy a simple LED bulb…
Could it be there is a difference in CAN bus speed between the two, I know the Evo has to run at 500Mb speed so was wondering if this would be the cause.
I have not yet tried to connect it to the second CAN bus on the Motec, would this be an option?
Any help regarding this will be highly appreciated!
Brian Thomsen
qatarevox
Re: SLM light not working
Postby SprinterTRD on Tue Aug 25, 2015 4:59 pm
The SLM will auto baud so 500K won't be a problem.
Have you set the CAN Communications slot correctly in "Communications Setup"?
SprinterTRD
Postby qatarevox on Thu Aug 27, 2015 5:03 am
Hi SprinterTRD,
Thanks for clearing up the baud rate issue, this was what I was most worried about, I will check settings again but pretty sure they are correct. Thanks again.
qatarevox
Return to M800 Plug-In ECUs
Users browsing this forum: Bing [Bot] and 2 guests
