Evo 9 M800 PNP Lambda Wire Setup
Postby Ohachicho on Mon Jan 12, 2015 4:45 pm
Hi guys,
I'm pretty new here so bare with me a little. I just finished tuning my evo with the Motec, however we couldn't push the car's hp as I don't have lambda. So I bought the necessary sensors and wires to achieve my goal:
#61044 - M800 OEM Lambda Adaptor (6 pin OEM to DTM)
#61051 - M800 OEM LSU 4.9 Adaptor (DTM to LSU 4.9 Plug)
#57006 - Bosch LSU 4.9 Lambda Sensor (5 pin wire with resistor)
#64010 - Bosch LSU 4.9 Connector
The Lambda adaptor for M800 is 6 pin, and the LSU 4.9 has 5 visible wires... :!: :!:
What I want to know is which wires on the Lambda adaptor (6 pin) corresponds to which wire on the Lambda sensor (5 wires):?: :?: :?:
This information will be very helpful to get the lambda working. I already have the codes to run it.
Thank you for your input.
Ohachicho
Re: Evo 9 M800 PNP Lambda Wire Setup
Postby mstech on Tue Jan 13, 2015 9:14 am
Why do you need to change any of the pins/wires? you plug the parts together and into the ECU, and enter the enable code into the ECU and it will work.
mstech
Return to M800 Plug-In ECUs
