Have a problem with the following car:
MY 2007 STi SPEC C JDM version / Actually it is a N12b rally car (group N4 32mm restrictor)
The car came with INMOBILIZER, no automatic water spray, no A/C and manual water spray.
Have fitted a M800 WRX78 OEM board.
Cannot get the OEM spray injector to work ..... have already used the INJ 5 output and it doesn't seem to work when using OUTPUT TESTING.
I fitted a automatic water spray oem switch since the wiring loom was there, so just plugged it in and could get the M800 OEM ECU to change between ORB modes. But had no luck with the water spray.
Any suggestions ?
Cheers,
Carlos Hiraoka
Lima - Peru
