What does the SyncMag Sensor levels table look like?
Look in Adjust->Sensor Setup->REF/SYNC Sensor Setup->Sync MAG Sensor Levels
Read the help (press F1 when this table is displayed), it has hints on where to set the levels.
pftuning wrote:Is that a tiny bit of cross talk between cam and crank?
Chain wrote:Hi all thanks for the replies, sorry l haven't gotten back sooner but I was away.
Holmz,
Are you of the opinion thatthe ac voltage created by the crank sensor becomes too high at high rpm for the m800 , and the ecu needs to chop the voltage (maybe the ecu can't keep up with the crank sensor) and adding a couple of resistors would drop the voltage and give the ecu an opportunity to handle the voltage chopping?
