map sensor question
map sensor question
Postby andi m on Fri May 29, 2009 7:25 am
hi im trying to find out the values for a map sensor that i have setup for barometric comp on a m4
its from a 1.4 renault clio . a standard gm bosch type numbers on it are 876 2288
thanks andi
i
andi m
Re: map sensor question
Postby RossB on Fri May 29, 2009 10:10 am
This should be the same as our 1 Bar MAP sensor (100 in the M4 sensor calibrationo selection).
Postby andi m on Fri May 29, 2009 9:57 pm
tryed that setting and that one does not work , would figure that it would as its a 1 bar map
it comes up with a fault code as the output at 100kpa is 4.8v
andi m
Postby RossB on Mon Jun 01, 2009 9:46 am
Is the sensor reporting an error at 4.8 Volts? This is the correct voltage for 100 kpa on a 1 bar sensor. The sensor should not go in to error at this voltage.
Postby andi m on Tue Jun 02, 2009 6:16 pm
yes it reports a error at that voltage ,i tryed 3 different map sensors that i have as spairs and they all do it,
andi m
Postby RossB on Wed Jun 03, 2009 12:20 pm
What version of M4 software are you using? If you select "100" as your MAP sensor calibration it should not report an error at all at that end of the scale, it will only report an error below 0.1V. If you are using a custom calibration you will see an error at 4.8V.
