Race Grade Aero - 8 Not working
I have a Race Grade 8 channel differential pressure sensor that does not appear to be working. I do not see any data across the CAN bus when checking with a scanner. Baud rate of the sensor is supposed to be set at 1mbt, but I've tried changing the scan rate just in case and it still does not see anything.
There is no power indicator on the sensor. Anyone familiar with these that might have an idea on how to check to make sure it's powering on?
The Autosport pin numbering is hard to read - there is a possibility I'm off one pin number on the power pins, but I'm 95% sure I have it right, Having a way to know if the sensor was on would be helpful.
