Race Grade Aero - 8 Not working
Postby speedsport on Tue May 20, 2025 1:15 am
I have a Race Grade 8 channel differential pressure sensor that does not appear to be working. I do not see any data across the CAN bus when checking with a scanner. Baud rate of the sensor is supposed to be set at 1mbt, but I've tried changing the scan rate just in case and it still does not see anything.
There is no power indicator on the sensor. Anyone familiar with these that might have an idea on how to check to make sure it's powering on?
The Autosport pin numbering is hard to read - there is a possibility I'm off one pin number on the power pins, but I'm 95% sure I have it right, Having a way to know if the sensor was on would be helpful.
speedsport
Re: Race Grade Aero - 8 Not working
Postby David Ferguson on Tue May 20, 2025 2:25 am
The RaceGrade brand is from MoTeC USA, and you can contact them through their Milspecwiring.com website. I would just call them and ask for support. 704-799-3800
