Injector opening time measurment.
Tue May 19, 2009 9:50 pm
by Polux RSV
I have measured opening time using a probe wich displays the current waveform on the oscilloscope display. The waveform shows the core rebound and I can measure the timings at different voltage. But this is done in my lab, without fuel, thus no pressure inside injector.
Will the timmings be different when injectors are fitted, with fuel pressure ?
Angelo
Re: Injector opening time measurment.
Wed May 27, 2009 5:35 pm
by DarrenR
Hi Angelo,
Do you mean you can see when the actual pintle is opening?? And you want to know if the pintle opening time will change with different fuel pressures?
I can tell you it does change, obviously with a change in voltage, but also with a change in fuel pressure and that is why we have a 3D table for injector 'dead time' so you change your fuel pressure and know the 'dead time' comp is always correct.
Typically the 'dead time' is longer for more pressure but not always.
Here is dead time at different fuel pressures for an injector we have characterised.
At 14 volts the dead time is -
At 3 bar = 584mS
At 4 bar = 646mS
At 5 bar = 679mS
At 6 bar = 755mS
This is calculated from actual fuel flow so takes into account injector closing time also.
Cheers,
Mon Oct 19, 2009 2:43 pm
by killerbee
You might want to contact Paul Yaw at yawpower.com. He tests and characterizes the non-linear behavior of injectors over a range of voltages and operating pressures.
Sat Apr 03, 2010 10:13 pm
by Holmz
DarrenR wrote:Hi Angelo,
At 3 bar = 584mS
At 4 bar = 646mS
At 5 bar = 679mS
At 6 bar = 755mS
Cheers,
Darren - are those units mS (milli seconds) or uS (micro seconds)?
Fri Apr 09, 2010 10:44 am
by DarrenR
Holmz wrote:Darren - are those units mS (milli seconds) or uS (micro seconds)?
Ahh yes, micro seconds ofcourse... So should be
At 3 bar = 584uS
At 4 bar = 646uS
At 5 bar = 679uS
At 6 bar = 755uS
Thanks for pointing that out.
