Stephen Dean wrote:Are you unplugging from the Vehicle CAN Bus when connecting the PCAN device? It may be between the TC8 and Dash that the CAN Bus is picking up the noise.
David Ferguson wrote:The PCAN devcie may be optically isolated (I think mine is), and might be able to handle larger differential voltage offsets. Again, my experience was an induced 30v offset onto the CAN bus that caused the problem - shielding the CAN bus helped, but fixing the short in the motor case, solved it completely.
