Temp sensor on analogue voltage
Postby tsadilas on Fri Mar 24, 2023 8:45 am
Hey,
perhaps stupid question but im new at this so....
i have quite a few 2-wire msel temp sensors (SENTEMSSNPT) for my diffs , transmission etc.
the m150 doesnt have enough analogue temp sensor inputs.
msel datasheet states that it can work on 5v instead of groung resistance as well.
can someone tell me how to wire this 2pin sensor for use with any of the analogue voltage inputs on the m150?
thank you
tsadilas
Re: Temp sensor on analogue voltage
Postby Stephen Dean on Fri Mar 24, 2023 8:56 am
This diagram shows what needs to be done.
ImageAT sensor into AV input by Stephen Dean, on Flickr
Postby tsadilas on Tue Apr 11, 2023 9:13 am
Bit of a wiring headache but it works fine thank you!
tsadilas
Postby hamer on Fri Jun 30, 2023 4:07 am
Stephen Dean wrote:Hi,
I assume this would also work for an AV input on the C125? Assume calibration table stays the same?
hamer
Postby Stephen Dean on Fri Jun 30, 2023 5:23 pm
Correct and Correct.
