Wiring lambda sensors to Dual NTK Lambda to CAN
Hi all,
I am wondering if a longer lambda sensor loom extension can be used than what is currently available? I believe the longest off-the-shelf loom extender is 0.55m (1.8 feet). FYI, the NTK lambda sensors I am using are part #57007.
Would it be an issue to add another 1 foot of wire length in a custom loom and also incorporate a bulkhead connector to then connect both lambda sensors to the LTCD-Dual NTK (#61305) which will be inside the vehicle for connection to my CAN Bus?
Thanks,
Neil
Thanks,
Neil
