Wiring IGN1A
I have a set of IGN1A coils that I would like to use with my M150. I am a bit confused on how to wire them up...the coils have the following pins:
A - Trigger (0-5V)
B- Sensor Ground (ECU Ground)
C- Cyl Head Ground
D- Battery Ground
E- 12V+ (Switched)
So... C, D, and E are pretty straight forward.
A and B are less clear. I understand what the ignition coil is expecting to get wired there, but I don't know how to accomplish this with the M150. The ignition outputs on the M150 drive to ground, so I don't think I can use these as the ignition trigger, since the trigger needs to go to 5V+. I am wondering if I could instead wire a 5V+ reference to "A" and wire the LS Ignition outputs to "B"? This way it the A would see 5V+ when the ignition output was ON, and 0v when the output is OFF...correct?
If this wouldn't work, any suggestions would be appreciated.
Thanks!
A - Trigger (0-5V)
C- Cyl Head Ground
D- Battery Ground
E- 12V+ (Switched)
Thanks!
