MAP Sensor Failure after 8 hours
Hey all,
Just wondering how temperamental or perhaps delicate a MAP Sensor actually is?
I've never had an issue with one over the years, however, 3 Bar Delco - brand new - ran fine without issue for engine dyno time and tuning on a fresh engine.
Put engine in car, connect MAP and instantly find a diagnostic error. Wiring is all good.
Car then exhibits all the usual MAP issues:
Hard to start
Sloppy throttle response (very evident on a 900hp motor!)
Stalls
Doesn't want to idle properly
Erratic rich/lean
Sure enough, unplug sensor and plug another one in - fault disappears and issues go away.
Sensor was never dropped or wet, but seems faulty after just dyno hours.
Are these perhaps more temperamental to damage than I have experienced before, or just a bad luck item?
Only thing I could possibly put it down to is the engine is on E85 and has an intake plenum injector. But I doubt any misted fuel (or moisture from sitting) would make it to the sensor - that's quite a stretch!
Anyone ever experienced similar? Curious more than anything.
Hard to start
Stalls
Erratic rich/lean
