No EGT sensors available? Part No:#58053
Postby fastech on Wed Mar 01, 2017 11:27 am
I just attempted to order an Exhaust Gas Temperature Sensor R1000 - Part No:#58053 (http://www.motec.com.au/ac-sn-temperatu ... rature-eg/) through my local Motec dealer and was told that it's obsolete and not available from Motec.
The car is running an old M8 and ADL and has an old K-type thermocouple installed, but missing the 'TCA—Thermo Couple Amplifier - For use with K-type sensors'. I thought the #58053 was the updated option as doesn't requite the amp.
Anyone have additional info or alternatives?
Thanks in advance,
David
fastech
Re: No EGT sensors available? Part No:#58053
Postby David Ferguson on Wed Mar 01, 2017 12:39 pm
Where are you located? It's a good idea to update your profile in the Control Panel.
We have been very happy using EGT sensors and amplifiers from Exhaust Gas Technologies.
http://exhaustgas.com/ProductDetail.asp ... ID=&RepID=
Paso Robles, California USA
Postby Stephen Dean on Wed Mar 01, 2017 4:18 pm
Hi David,
Honeywell, the manufacturer of the R1000 EGT probes stopped making these sensors about a year ago, we have been trying to source replacements for them, but it is not as easy as it may seem. Most of the current non K-Type EGT sensors on the market only read to 900 degrees, and fail at temperatures higher than this.
We hope to have a replacement sensor for these soon, but no timelines can be given at this stage.
Postby fastech on Wed Mar 01, 2017 5:17 pm
Thanks David, I'll look into them. And thanks for profile update suggestion (i live 10 mins from Motec actually).
Thanks Stephen for confirming that these are no longer available. Are the K-type sensors and Amplifiers still available through Motec?
Appreciate the help
David
fastech
Postby Stephen Dean on Thu Mar 02, 2017 8:05 am
We still have the K-Type sensors and amplifiers available.
Postby fastech on Thu Mar 02, 2017 9:17 am
SDean wrote:We still have the K-Type sensors and amplifiers available.
Excellent, thanks Stephen.
fastech
