Injector Battery Comp
Sun Jan 18, 2009 1:53 am
by Martin
Could somebody please help me with the Injector battery comp for the standard "yellow injectors" found on the Mazda RX8 High Output (6 injector) engine? its 14.1 Ohm
I also need the Bat comp for "RC SH4 -750" injectors. They are 750cc 12.2 Ohm injectors. Ill be running them at 400Kpa
Re: Injector Battery Comp
Thu Jan 29, 2009 8:45 am
by JamieA
please supply full part numbers and manufacturer details for the injectors.
We have many characterised, but by injector number not car.
-Jamie
Thu Jan 29, 2009 7:01 pm
by Martin
Martin wrote:Hi,
Ill get the partnumber from the standard car
That is the part number, and RC makes them
http://www.rceng.com/Saturated-Injector ... P63C6.aspx
Fri Jan 30, 2009 12:27 am
by Martin
Martin wrote:Martin wrote:Hi,
Denso 195500-4450 Yellow
Fri Jan 30, 2009 8:48 am
by RossB
We haven't tested that injector here. If you wanted to send one to us we can do it.
Fri Jan 30, 2009 11:56 am
by Dragon
1.36 10v
1.12 11v
0.92 12v
0.76 13v
0.63 14v
0.50 15v
Try these for the RC injectors that you have.
Sat Jan 31, 2009 5:48 am
by Martin
Thanks,
The values that you mentioned, are they in mS?
Your help is appreciated
Mon Feb 02, 2009 7:42 pm
by Dragon
Yes, ms.
Tue Apr 21, 2009 3:25 am
by Martin
Rx8 Yellow Injector
