M4 - Off Car ECU Connection
I have an M4 ECU and wish to be able to upload new ECU configuration data away from the car via my home PC. What are the minimum connections required to the ECU ?
Can I confirm the following minimum connections are required (For late series M4 ECU)
Power:
Pin 1- 12 V
Pin 25 - Gnd
RS232:
Pin 21 - RxD - (connected to pin 2 on PC's D9 connector)
Pin 22 - TxD - (connected to pin 3 on PC's D9 connector)
Pin 23 - Gnd - (connected to pin 5 on PC's D9 connector)
Are the RxD and TxD pins correct for the PC's D9 connector ?
Are there any other connections required ?
Many thanks
Toby
Power:
Pin 1- 12 V
Pin 25 - Gnd
RS232:
Many thanks
Toby
