GM 4-Wire stepper IAC
Is there a recommended part number for a GM 4-wire stepper motor for IAC control, that is compatible with the M84 ECU? I know there are two different internal coil types, and I'm not sure if my current motor will work correctly.
It needs to be similar to this mounting type:
