GM DBW Throttle
GM DBW Throttle
Postby Martin on Tue Dec 02, 2008 5:58 am
Ive read that the GM DBW throttle`s are not the strongest and that the gears driving the throttle are fragile. Is this of any concern when deciding what DBW throttle to run on a 550Hp LS2 to be used in Offroad racing? The intake is OEM so GM would be preffered but not if it will decrease reliability.
My other option would be a 84mm VDO. Any suggestions or comments?
Re: GM DBW Throttle
Postby figgie on Wed Dec 03, 2008 2:08 am
Heard or seen?
I have heard lots of things and each one I take with a granual of salt. I have yet to see any real failures.
figgie
Re: GM DBW Throttle
Postby Martin on Wed Dec 03, 2008 2:56 am
Ive Read it :)
Have you used GM DBW units? what do you think?
Re: GM DBW Throttle
Postby figgie on Wed Dec 10, 2008 6:06 am
Yes
in particular the GM DBW off the 2006 Chevrollet Corvette and the E-Throttle pedal off the same car as that is the same size DBW they use on the LS7 based Corvettes.
Works really well for such a big throttle.
figgie
Re: GM DBW Throttle
Postby MarkMc on Tue Jan 13, 2009 10:11 am
We have found this in testing (Ask Peter Swinney, haha) but it was mainly the very early smaller throttle bodies (76mm I believe). The gears are weak and do not seem to take any real abuse. I also had the motor windings in one of these DBWs fail in the middle of a rally. I think the later versions of this throttle body were much better and have not seen a gear failure for a number of years.
The later 80mm throttle bodies appear to have no such problem and we have a number of these on customers cars. Figgie, you will notice the shape of the throttle bore at low throttle openings is quite complex, allowing the throttle to act like a smaller one at idle and light loads, you see this a lot on modern throttle bodies.
If you were in Australia I would suggest the Ford BA/BF DBW throttle as they seem the be failure free....more or less opinion though. :)
Re: GM DBW Throttle
Postby figgie on Mon Feb 02, 2009 6:23 pm
Yes, I saw that it is not like a regular TB. It is machined to open a bit at a time. This TB has about 110 degrees worth of opening. I always found the opening while in the lower section curious and assumed that is how they keep such a big TB behaving nicely at low TP. :)
figgie
