Diagnosing TPS issue
I have a Motec 48 system with a TWM ITB setup.
with a
D-Drive white throttle position sensor, LH #56002
This weekend I was exhibiting some odd (and dangerous) behavior.
My normal idle is about 1000rpms. On track my throttle seemed to stick at 4K rpms.
Came off track and if I shut down the car. Some times I'd fire back up at 1K rpms,
sometimes at 4K (or slightly higher) RPMS. Never touching the throttle.
If when I did fire up at 1K rpms, I could modulate the throttle and return to 1K rpms
as long as I kept it below about 3000 rpms (non-scientific testing). But if I went above
about 3000 RPM or so I would stick at 4000 RPMs (or higher if I adjusted the throttle
accordingly) -- It would hold there even as the linkage was returned.
Most times if I killed the ignition and restarted, it would fire back up at normal idle.
This suggests to me the linkage is not the issue. As firing up there is no mechanical change relative to
shutting down at high RPM and starting again.
Note after packing up and returning home -- I could not get things to repeat -- I think there
might have also been an engine temperature or sensor temperature relationship.
What suggestions might one have for testing the TPS?
measurements -- etc?
thanks,
Mike
with a
thanks,
Mike
