Page 1 of 2
Datasheet for sensor 57102 ...
Sun Nov 02, 2008 12:03 pm
by Vspec r33
Ive been trying to locate a data sheet for the 57102 hall effect sensor but havent had any luck. I need to know the temp operating range, as i want to mount the sensor through the front of an engine block to trigger from the camshaft drive gear.
Can you provide a data sheed or details about its reliable operating temp range?
Cheers,
Ian
Re: Datasheet for sensor 57102 ...
Sun Nov 02, 2008 7:42 pm
by Merlin
if its going to run in oil ...then NO....I tried and the sensor failed each time once the oil got over about 50 deg C
John P
Mon Nov 03, 2008 2:32 pm
by Vspec r33
Is the datasheet available for this sensor somewhere?
I could always machine up a cover that would protect the senor from direct splashed oil to a degree, but I still need to know the reliable operating temperature range.
Cheers,
Ian
Mon Nov 03, 2008 3:58 pm
by JamieA
it is MDHall 437, and here is the spec sheet that we have for it.
I know it doesnt answer your questions, so I have asked for a clarificaiton of it for you.
-Jamie
Tue Nov 04, 2008 5:12 pm
by Vspec r33
Thanks Jamie, looking forward to seeing a manufacturer specs data sheet on the sensor.
Cheers,
Ian
Fri Nov 07, 2008 11:48 pm
by Vspec r33
BUMP!
Im hanging out to get this data sheet guys. The whole engine build process is on hold till I can locate a sensor that will do the job.
Cheers,
Ian
Mon Nov 10, 2008 9:07 am
by JamieA
I have sent another email asking for info....
Mon Nov 10, 2008 2:58 pm
by Chris
That sensor is designed for wheel speeds, and likely will not handle engine temperature. Rather than the DHall 437 you can choose an MHall which is a mag sensor rather than a hall effect. The mag sensor does not have sensitive electronic inside, so it can handle high temperatures.
Tue Nov 11, 2008 9:08 am
by JamieA
A correction for the thread on this topic as well. The Mhall 437 is a hall effect sensor, not a mag sensor. The difference between the two is the Dhall triggers on ferrous material, the Mhall triggers only from a magnet. We have had great success using the Mhall as a cam sync pickup. (MoTeC USA sensor names used there)
As for an answer to your question, what sensor to use, where are you located? We are looking at a new sensor that may suit your application. It is a hall sensor, has a 0-150deg temperature range, and we have been testing in oil, reading from the front of a camshaft.
email me if you would like more details.
jamie.augustine@motec.com.au
Wed Dec 03, 2008 3:21 pm
by SportsCarRacer
Try one from a Ford Duratec 2.0 & 2.3 / Mazda MZR I4 (focus, 3, 6, mx5 2006->, escape, tribute, ranger,etc) . They have one mounted in the rocker cover, in oil, with good o-ring sealing to keep oil in engine, and work a treat. They are essentially a conditioned mag sesnor, with digital output, run from 5-12v. Temp range no probs, have had my oil to 145C with sync or sensor failure. Might be able to get you a Ford part number, they are Very common.
else use a mag sensor like on Ford modular V8's post 2002 (Us lineup & aussie falcon V8, I6 uses same style of sensor,m in the oil....no dramas ever...i work in OEM).
Have used these on road & race cars, without EVER having a failure....being auto OEM parts, they meet stringent temp & enviromental durability.
Not taking away from the MoTeC parts, but i find these cheap & simple coz they were actually designed to do the job you asking to do!
