Fuel level sender
I have just purchased an M800 for a land speed car and want to install a fuel level sender into the plastic fuel cell. I was think about using a VDO unit, two wire, i.e earth and sender that has a 10-180ohms range. Part No 220-003. Will this work?
Is it as easy as using a spare AV input and wiring it up? There has been a post about filtering to smooth out the signal. Any suggestions?
Gaz
Gaz
