Two Hall effects down one 6 core screened cable OK?
I have some Raychem good quality six core screened cable, can I use it to wire two Hall effect (GT101) rear wheel speed sensors down the single cable, or should I use separate 3 core cable for each sensor? If it makes a difference the six cores are twisted in a spiral along the cable inside the braid.
The GT101's have about 5 inches of unscreened cable off them, does that bit matter, or should I cut it back far enough to just get the Deutsch DTM 3 way connectors I want to use on? Thanks.
