Two Hall effects down one 6 core screened cable OK?
Postby Chris Wilson on Fri Sep 23, 2011 10:16 pm
I have some Raychem good quality six core screened cable, can I use it to wire two Hall effect (GT101) rear wheel speed sensors down the single cable, or should I use separate 3 core cable for each sensor? If it makes a difference the six cores are twisted in a spiral along the cable inside the braid.
The GT101's have about 5 inches of unscreened cable off them, does that bit matter, or should I cut it back far enough to just get the Deutsch DTM 3 way connectors I want to use on? Thanks.
Chris Wilson
Re: Two Hall effects down one 6 core screened cable OK?
Postby OmarK on Mon Oct 03, 2011 3:55 pm
I don't think that the signals should interfere with each other in the six core cable and it will be fine as it is from the deutsch connector to the sensor. Cheers, Omar
OmarK
Postby Chris Wilson on Mon Oct 03, 2011 7:05 pm
Thanks Omar, that's reassuring, just wanted to check, cheers for the reply.
Chris Wilson
