RPM reading from MSD ignition box
Can anyone tell me if I can read an rpm signal which is output from an MSD ignition box which is normally used as a tacho output ? How do I go about doing it ? Digital input or ref input ?
It states in the manual that the MSD ignition box outputs a 12V 20% duty cycle square wave signal for the tacho output, can I get the ECU to read this as RPM as its installed on a Carburetor engine with points ignition which I'm just using for some Lambda logging.
Here is the link to the MSD box http://www.msdignition.com/Products/New_Products/6425-Digital-6AL-Ignition-Control.aspx
