Pressure Sensor
Everything has been going well until yesterday .
I am using 2 pressure sensors on my engine.
The OEM is linked to the M800.
I have a honeywell to monitor pressure and to display to a MDD.
Normally on idle its around 250 ( dont know what this figure is )
When i rev it goes to 550 around.
While i was driving yesterday it went to zero. Then all of a sudden rose to 550 again only to drop to zero.
Its located in the top half of the sump in the oil gallery after the oil pump.
BTW the engine oil pressure light is operating as per normal , as it starts the light goes off.
I have another pressure sensensor on my fuel rail and thats constant 330
Im sure the fuel pressure one is 100 psi unit and the oil one is 250 psi unit.
btw checked wiring and there is no broken disconnected lines that i can see.Engine temps as per normal no overheating
Am i experiencing a sensor failure ?
Any comments/help is greatly appreciated.
Im going to change the oil soon , should i just replace it for the 500 psi unit ?
