Hall Sensor Recommendation
Can anyone recommend a Hall Sensor to suit a trigger wheel of the following dimensions-
117mm (4.5") OD
5mm thick
5mm teeth spaces (35 tooth + 1 missing)
5mm tooth height
The data sheet on the Motec ones state 10mm gap and 6mm thickness min requirements.
I have been told by some they will still work fine though.
117mm (4.5") OD
5mm thick
5mm tooth height
