Lambda Sensor Bosch 0 258 017 066/067
Re: Lambda Sensor Bosch 0 258 017 066/067
Postby Tommy on Tue Oct 19, 2010 4:42 am
Steve,
this sensor might be a Denso #234-4203
Review the image it's the same sensor. The lead at the end of the sensor makes me believe that it's not a Bosch.
http://www.densoaftermarket.com/catalog ... &part=o2sn
Tommy
Postby stevesingo on Tue Apr 19, 2011 4:11 am
I now have the engine running and these sensors (Bosch 0 258 017 066/67) work fine when set up as LSU 4.9.
Steve
stevesingo
Postby otto69 on Tue May 10, 2011 10:25 pm
I also have the same Ford p/n as these, 8F9A-9Y460-BA. But the Bosch # is different, 0 258 017 174/175.
I ordered them as a 0 258 017 025 and this is what I got. Do I need any calibration tables or cal numbers to set them up in a M800 ??
The plug p/n is 1 928 405 207.
Thanks in advance
Clayton
otto69
Postby stevesingo on Wed May 11, 2011 10:28 am
If you do an air calibration you should be fine.
HTH
Steve
stevesingo
Postby otto69 on Wed May 11, 2011 9:32 pm
Thanks Steve
otto69
Postby formulauem on Sat Jun 18, 2011 10:56 pm
Hi!!!
Does anybody know what means error C-6 of lambda sensor??? Broke lambda?
Thanks!
formulauem
Postby Carlos Iglesias on Sat Jun 18, 2011 11:07 pm
Must be viral... I'm in the same situation. Could clearly see where the error first occurred on the log as the lambda values abruptly "flatlined" at "0.6".
formulauem wrote:Hi!!!
Thanks!
Carlos Iglesias
