Plex Knock Monitor CAN Template
Re: Plex Knock Monitor CAN Template
Postby David Ferguson on Mon Jun 19, 2017 11:00 am
Great Info!! i didn't realize that older Color Dash Managers would produce .CC7 files.
Postby adrian on Mon Jun 19, 2017 11:21 am
In v1.9/5.9 we added the ability to lock/hide information in the CAN templates, which required us to change the format of the communications templates.
Postby killerbee on Thu Jun 22, 2017 3:24 pm
Two (2) other questions:
Can this CAN template be used on CAN 1 rather than CAN 2 ?
Engine RPM is listed in the PLex template. This name conflicts with an existing channel name. When I try to change it ity appears I can only select another one. So how do I create a channel with an appropriate name (say "Engine RPM Plex") so I can select it ?
killerbee
Postby adrian on Thu Jun 22, 2017 3:46 pm
Yes you can use it on either CAN bus, the main consideration when doing this is the address the Plex unit is using. The dash does restrict a couple of address ranges on CAN 1 that are used with various MoTeC to MoTeC comms.
A list of these addresses can be found here
With the RPM conflict just select another RPM channel (Engine RPM 2 for example) and then go to Tools>Edit Channels, select the RPM channel and then click edit. You can then change the name to whatever you like.
