ECU test rig
Re: ECU test rig
Postby 20B on Fri Mar 02, 2012 6:28 pm
Just ordered the 'jimstim' kit fully assembled for $99AU delivered to my door, thanks for the tip !
Mazda 1993 RX7
20B N/A engine
20B
Re: ECU test rig
Postby stevieturbo on Sat Mar 03, 2012 5:49 am
AdamW wrote:No you dont need it connected, the "wheel pattern" is selected via dip switches. It may be easier to configure when connected to a pc but I havent needed to try yet - I mostly work with 36-1.
So is it a fixed rpm signal, or variable ? Reading the description, it looks like rpm can only be varied via laptop communication ?
Are the mag trigger wave patterns of a low voltage, or would they simulate the high clipped voltages seen as rpm rises ?
Re: ECU test rig
Postby AdamW on Sat Mar 03, 2012 7:53 am
RPM is variable via pots on the board. There is one for coarse RPM and one for fine RPM. I dont know what the wave form looks like as I havent scoped it but you can choose either square wave or simulated VR output, my M48 accepts either ok. I havent tried any extreme high RPM yet but at about 8000 everything was going fine.
This is the only note I can find about the wave form: "The jumper allows the tach signal to either be a square wave signal (similar to a Hall sensor signal) or a VR signal emulation (not really VR signal-shaped but has zero crossings which works with an LM1815 circuit and the V3.0 VR conditioner)"
Motorsport Electronics Ltd.
AdamW
Users browsing this forum: No registered users and 30 guests
