Can G-SENSOR #57213
Can G-SENSOR #57213
Postby Donovan CR6 on Tue Sep 12, 2017 5:50 pm
Im trying to setup the can G-sensor #57213 on a C187 is there a template for it?
Thanks Don
Donovan CR6
Re: Can G-SENSOR #57213
Postby Stephen Dean on Tue Sep 12, 2017 6:02 pm
Hi Don,
Please find attached config. You may need to import it into the Dash manager that you are using as it is designed for the older version of Dash Manager.
3force_datasheet.pdf
(199.18 KiB) Downloaded 1239 times
3Force Combined Sensor.cc7
(8.12 KiB) Downloaded 1177 times
Postby Donovan CR6 on Tue Sep 19, 2017 10:09 pm
Thanks :D
Donovan CR6
