PLM Code C3
I've got a used "Like New" PLM that came with extended cables and is in very nice shape;
The problem is that upon startup it displays code C3, firmware is 1.1.2
Sensor is Bosch LSU4.9 but I suspect that something in the wiring between the Screen and the Bosch LSU4.9 Sensor isn't right...
I "calibrated" the unit using the MoTeC PLM Manager Software using the LSU4.9 Dialog but nothing changed...
Also, the Screen displays Upside Down, meaning that when the "MoTeC" Emblem is underneath the screen, the display is inverted
Thanks for your Input
