Need to replace lambda sensor on LTCD
one of the lambda sensors connected to the LTCD failed the free air calibration, so I have to replace it.
Can it be replaced with a standard Bosch LSU 4.9, or do I have to order one from MoTeC.
If it is ok to use a standard Bosch sensor, shall I use the "Initial Factory Sensor Calibration" option in the MoTeC LTC Manager when installing the new sensor?
