Need to replace lambda sensor on LTCD
Postby picasso on Wed Sep 05, 2018 5:20 am
one of the lambda sensors connected to the LTCD failed the free air calibration, so I have to replace it.
Can it be replaced with a standard Bosch LSU 4.9, or do I have to order one from MoTeC.
If it is ok to use a standard Bosch sensor, shall I use the "Initial Factory Sensor Calibration" option in the MoTeC LTC Manager when installing the new sensor?
picasso
Re: Need to replace lambda sensor on LTCD
Postby Stephen Dean on Wed Sep 05, 2018 9:32 am
You can order a Bosch LSU 4.9 from any supplier and use them with the LTC units. If it is a genuine Bosch sensor, then you can use the "Initial Factory Sensor Calibration" option, as this reads the internal calibration resistor in the LSU connector to set the calibration value.
Return to PLM & LTC
