I am looking into getting an LTC. I noticed that the manual says that the LTC will not operate correctly with a Bosch LSU 4.9 sensor if the factory connector with the calibrated trimming resistor is cut-off. Is it possible to use the LTC without this factory connector (and resistor) if you do an air calibration of the sensor?
If not, I'd love to know why this is not an option (especially as it could be done easily in the M880 with lambda option).
