Display light
Display light
Postby monaro308 on Tue Sep 09, 2008 8:24 pm
Hi all new member here.
A couple of questions regarding my PLM.My display light flickers on and off but doesnt stay on.I have checked the software settings (95%) and no good.I know the light works but its off most of the time.
Also is the cable available for flashing the firmware or is it easy to make one up?
Cheers....maz
monaro308
Re: Display light
Postby RossB on Wed Sep 10, 2008 10:11 am
Do you have a good power supply to the PLM? If the power supply is not good the backlight will flicker.
The firmware is not up-gradable in the field, the PLM has to be returned to MoTeC for upgrading. There is no charge for this, you just need to organise it through your MoTeC dealer. The backlight operation could be checked at the same time.
Re: Display light
Postby monaro308 on Wed Sep 10, 2008 10:18 pm
Ahh ok thanks for that info Ross i will get it organised.
Cheers....thanks MAZ
monaro308
Return to PLM & LTC
