And is this ignition system sensitive regarding wich ignition wires to use?
Should I isolate the wires good to prevent interferance or is this not so important with this system and coils?
Thanks for helping me out!
Best Regards: Christopher/ Sweden
SprinterTRD wrote:Either core will work the same.
Which wires are you talking about? Primary or secondary? You should follow the CDI8 drawing for primary wiring.
