Porsche Replacement CDI
When replacing a twin spark porsche`s 2 CDI`s with 2 Motec "porsche replacement" CDI`s, how will the RPM limiting be done?
I have done one such a car and both Motec CDI`s RPM limit is set to 6500 Rpm (done at motec prior to shipment). The problem is that the car revs through the RPM Limit, so effectively its not fully functional. I think that the problem is that the randomiser effect will have the 2 CDI`s cut separate cylinders so in effect some cylinders still get spark even though limiting is active. Is there is a way to solve this problem?
