CDi 4 (Part 41011)Wiring
PostPosted: Mon Jun 08, 2009 4:34 am
by toby
I am wanting to run a CDi 4 on a 4 cylinder engine in sequential format. The existing wiring has all 4 coil negatives grouped together. Assuming the current capacity of the wiring is sufficient, is it possible to feed all 4 coil negatives into pins 5 and 6 thus effectively linking pins 5 and 6 together? On the basis that 2 coils are linked to pin 5 and 2 to pin 6, this should not be a problem I think. Am I correct?
Re: CDi 4 (Part 41011)Wiring
PostPosted: Wed Jun 10, 2009 2:21 pm
by RossB
Yes you are correct, this will work ok.
