Bosch coil 9 220 061 710
Postby prostang on Mon Jan 05, 2009 7:10 pm
Hi all
is the bosch coil 9 220 061 710 ok to use with a cdi igntion :?:
thanks
steve
prostang
Re: Bosch coil 9 220 061 710
Postby MarkMc on Thu Jan 08, 2009 12:00 pm
Hi Steve,
It is a bit hard to give a guaranteed answer without trying it. Realistically inductive coils are designed differently to CDI coils so you would be using it outside of what it was designed for.
Postby prostang on Fri Jan 09, 2009 5:53 am
hi mark
thanks forthe reply, im just changing from a autronic sm4 to the m800 i am using your ignition expander to feed 2 autronic r500 cdi boxes what coils do you reccomend for a high hp supercharged engine v8 coil per plug
steve
prostang
Postby PQatPIT on Sun Mar 01, 2009 2:18 am
Crane Cams LX-92 and MSD #8230 have produced some good results. Also price is decent.
PQatPIT
Return to Ignition systems
