Crank angle sensor setup confusion!!
hey guys, i have a question regarding crank angle sensor setup.
currently i am running a 4agze CAS on a 16v 4age cylinder head, i am wanting to delete this CAS completely, and block up the hole for exhaust header access. If i mount a trigger wheel and sensor of the front balancer, am i required to run a sensor of the exhaust cam pulley to reference sync, and how do i set the ignition timing at idle with no physical way now of doing this. Is what i am trying to achieve possible?
I am running an M4, the engine currently runs 4 individual nissan s13 coil on plugs and a bosch 4 channel ignition module, and i am running them sequentially using IGN and AUX outputs, which i am going to change to and IEX that i have purchased.
can anyone help?
Brad
can anyone help?
Brad
