otto69 wrote:Looking at fitting LS coils to a 302W with M84.
What model would be the best, LS1, 2, 3, 7 etc ??
Can I gang two together for waste spark straight from the ECU ??
Does anyone have the setup details for the coils (wiring & valves) ??
cheers
Clayton
Whatever is most easily available. They are all very good coils. The favoured D585 truck coils seem to be harder to get hold of these days.
After that I think the square D510C are preferred and then the D514A after that.
Sidenote, do not buy from a seller Evalero1 on ebay, he sells cheap chinese copies that will fail within minutes.
Yes you can fire them as wasted spark by pairing the ecu outputs.
Just google "LS2 coil pinout" on google or google images. There is plenty of information on their wiring.
As for specific Motec values...not sure.
These coils require a 5v signal to charge, and when this is removed they fire. falling edge. Dwell time would typically be 4ms.
Some may allow more, but 4ms is usually plenty for most applications.
