Ignition system Subaru Impreza
Postby Bjornar on Sat Sep 13, 2008 3:42 am
I need some advice what type of ignition system I should run in my Impreza.
This is a car I've built for circuit racing. I run with the Motec PnP M800. I have a fully built EJ25 engine with Cosworth big valve heads. I run a GT35 turbo, will run 26 - 28 psi boost and redline 9000 rpm.
I'm using E85 (ethanol) gas.
One of my original coils have broken and I'm wondering if I should change to a CDI system or... :?:
Any good suggestions?
03 Impreza HTS edition
Bjornar
Re: Ignition system Subaru Impreza
Postby mhd on Sat Feb 28, 2009 8:26 pm
I'm running Subaru 2.71L Gt35 Turbo 1.8 Bar with stock ignition and I don't have miss firing or any proplem with the ignition system
Try to check the dwel time
Regards
M.Olabi
ProRacing Co.
mhd
Return to Ignition systems
